J30 5 Lug
b0rdin4life
Car: 95 240sx
I just picked up a wrecked 93 J30 and I have someone who is interested in the 5 Lug off the car as long as it will fit the 240. I have searched and searched and I keep getting mixed information. The most consistent information is that only the rear will swap over to the 240. Can anyone tell me if the 5 Lug is swappable and if so, if the front and rear will work? Any info would be great. Thanks.
SmithSR
Car: 240sx
front won't work. it interchanges with Z32, not the S chassis.rear will work, just like the Z32 with uprights and might as well sell the brake kit too.The shafts and diff are also interchangeable with the s chassis, so hang on to that too.
b0rdin4life
Car: 95 240sx
Can I use the brakes off the J30 as an upgrade for my S14? Thanks for the info.
SmithSR
Car: 240sx
Yes. The rears especially. Look to the rears for a thicker and vented rotor as opposed to the s chassis solid.
Q45tech has mentioned this several times as a great find.
b0rdin4life
Car: 95 240sx
Awesome, thanks. I tried looking up Q45tech posts but didn't see the one about the brakes. Do you happen to know if it's a simple upgrade and also what is involved? Thanks again.
hannibal
Car: Red Line to Glenmont
Very similar to installing rear Z brakes. The j30 rears are the same as 97-01 Q45 rears. You'll need the parking brake drums from the J30.
Heres a good write-up you can use.http://importnut.net/300zxbrakeswap.htm#rearbrake
b0rdin4life
Car: 95 240sx
Getting ahold of all the parts off the car won't be an issue because I have the whole car. Any other upgrades I can take off the car besides the diff? Thanks.
hannibal
I assume your grabbing the front brakes as well. They are very similar to the 90-96 Q brakes. Same sized rotor, and the calipers look very similar. I havent been able to find a J30 FSM to determine if they are in fact identical.
The MAF is the same as a Z32 MAF. You should grab that as well.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The front J brakes are the same as the front Q brakes ..
Anyway... I would suggest posting up the parts for sale in the infiniti parts if you havent already...
rpd240
Car: 1996 240SX SE
I was searching and couldn't find anything except for this. Can you use the j30 parking brake assembly with z32 rear calipers on an s14?
SmithSR
Car: 240sx
cables and shoes interchange with the knuckles, so an S chassis knuckle or Z knuckle will accept S, Z, or J rear brakes and parking brake.
hannibal
^ Yep. And I believe the Q45's (90-96 G50) can be used too. I dont know about the cables though. I'm guessing the sedans' cables are longer than the Z cables so that shouldnt be a problem.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Wow dude.. J30 rear hubs work on the 240?? I can get them for $15...
:O
