J30 5 lug swap Q
RustspecS13
Car: '74 260z and '88 300zx turbo
So on the rear, what years J30 works. Because when I went to the yard earlier they had 3 92-93's and they all had integrated spindle/hubs.
So unlike the stock s13 style were you can take off 4 bolts and remove the actual spindle with the lugs and spline for the drive shaft, the j30s had a solid unit.
So my Q is this, do I swap the whole unit and bolt on all my brakes and suspension on to the j30 part. Or do I find a newer j30 that has separate spindle/hubs?
~Alex
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
edit: you ll need different upright sleeves to fit. Maybe this can help...
j30-rear-knuckle-on-240sx-install-t421150.html
RustspecS13
Hmm.
That gives me some ideas since I already have q45 brakes.
I need to re read up on the q45 diff/axle swap because I want stronger axles but I don't want to loose my kaaz.
~Alex
