fatalymadesicc »
https://forums.nicoclub.com/fatalymadesicc-u195890.html
Wed Dec 28, 2011 1:17 am
Ok I have search and search and couldd not find a POST with all the problems im having in one so Im posting a new.
Problem started very mild and has progressed and gotten worse. 1st I noticed it would hesitate from slow speed or from a stop for a good 3 or 4 seconds before acually responding with any kinda power, regardless how much throttle I apply.
couple weeks later I noticed the RPM fluxuating a bit on the freeway. then it started doing it to me at startup and having hard time starting and staying started without pumping the throttle and after start ill let it idle by itself but the RPMs goes crazy up and down. up to lil over 3 sometimes and drop all the way to 0 almost instantly and if it dont die it will pop back up to 3. nver staying in one spot for long. When it goes to zero I have to use the throttle and ill try to hold it at 1 rpm very steady with my foot not moving at all and the RPM will not stay. it bounces all over the place. seems like when I turn on the heater or AC it will help hold RPMs a little higher. But it wont last before the IRRATIC behavior of the RPMs and fluxuation with the fuel reaching its destination takes over and kills the car. So its IRRATIC idleing, stalling out either because its not getting enough fuel or too much... seems like just before the car starts acting stupid ill smell raw unburnt gas inside the car pretty storng at time. If the car is running smooth I dont smell the gas at all.. Now it will run good for a week, or couple day, or hours, and even minutes before it wants to start MESSING up again. Its very random and without warning. It has even stalled out doing 40mph coming off the freeway couple time but wasnt giving much throttle, only coasting with small amount of throttle applied and it died going that fast, not just at low RPMs. Sometimes on the freeway it will start jerking while im maintaining a steady speed holding the throttle steady. Feels like the transmission is dissingaging and rengaging and jerking forward not violently but it definatly cant be healthy for my motor or transmission.
I have replaced the ECU coolant temp sensor. after reading all the forums it sounds like it might be the MAF.
It started and progressed over the last 5 months and during that time I have had some other strange issues. The alarm going off by its self with no one around it and sometimes it will go off but it wont sound the normal car alarm sound it will be a steady horn sound with all the lights stuck on. the only way to turn it off is to disconnect the battery cable. It has went off while i was driving down the street, not the normal alarm but the stuck horn and lights on. also while driving the emergency 4-way flashers will come on by them selves, except they dont flash they stay on steady without flashing and again the only way to turn it off is to disconnect the battery. one last thing the door locks, while driving one day the locks kept locking every minute it would click, click, click as if someone was hitting the button.
None of the electrical problems has happend to me in the last 2 weeks but I know the cars idleing and starting is getting worse. All the test I see require the car to be idleing or at running tempature. But if I dont get in the car start it and drive away with one foot on the gas and one on the break its very difficult to keep it started and idling.
PLEASE HELP
300ZXttZMAN on Wed Dec 28, 2011 11:12 am, edited 1 time in total.
Reason: Spelling
