NL320Nick »
https://forums.nicoclub.com/nl320nick-u110209.html
Wed Dec 31, 1969 5:00 pm
I just completed a rebuild on a 67 J13, I had to go 40 over on the pistons, I got D11 pistons from motorpowerinc.com worked great they are dished not flattop so I guess the compression is slightly less, gasket kit from NAPA, I had to go under on all the bearings except cam which was standard, and new valves the machine shop got them no problem. I got the oil pump on ebay NOS lucky find they are hard to find but I think Motor power has one that will work, I think a J15 oil pump is the same. Water and fuel pump from NAPA. All complete including the machine work the motor was just under $1,000.00. Hope this helps.
Nick
