J13 ENGINE AND GEARBOX REPLACEMENT
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
DATSUN1300UTE
What motors could i use to replace my J13 engine and gerarbox?
71-521
whatever you want depending on how much work you want to do...:D
71-521
everything other than stock will require mounts, crossmember and sometimes driveshaft fabrication...
there is a member here who is doing a Ford 460!
DATSUN1300UTE
what motor will require little as possible fabrication??
71-521
J13...:P
then if you have to mod it, go for what's available...
if there is a L, vg, fj, ka, ca or sr available in your budget, do it!
NL320what
Car: '63 Datsun NL320 4x4
'04 GMC Yukon
'13 Chrysler 200 Touring
[user=167]DATSUN1300UTE[/user] wrote: [quote]what motor will require little as possible fabrication??[/quote]
You can find a Datsun Roadster U20 motor and 5 speed to install easily, hard to locate though.
If you get away from installing the J13, they do have J16 motors also.  Anything else would need to fabricate motor mounts and or transmission mounts, along with possible oil pan mods, and driveshaft.
62panel
I could REALLY use that J1300 engine over here, can't find one anywhere!!
Return to “Datsun Chat”
