2.7t »
https://forums.nicoclub.com/2-7t-u251224.html
Sat Jun 09, 2018 6:36 pm
Looking to change the steering fluid. Will only be removing whats in the reservoir. So far the thing is the fluid is yellow so it cannot be ATF...right?
What should I do? The Cap says use a Dextron but which one? A lot of dealers do not have J matic anymore and only S matic. Is it okay to use S matic on power steering fluid? Or should I just get the power steering fluid from Infiniti?
Also since my fluid is yellow is it okay to add the pink ATF fluid? I tested the color by putting a lint free paper in the reservoir and the fluid is not pink. Its clearish yellow.
