driverdriver »
https://forums.nicoclub.com/driverdriver-u9137.html
Sun Jan 31, 2010 3:59 pm
The first thing you need to do is drain about a litre of oil from your engine and replace with a litre of quality full synthetic oil like Mobil1 or Pennzoil.
See if this quiets it down.
Another go way to test is to add a half litre of transmision fluid to your oil and see if that quiets it down. However, I recommend changing the oil and oil filter right after the test.
The VTC solenoid is located towards the back of the engine. Its half under the cover and half out side. You can find it by listening for it.
In J30 FSM look in the EC section. There is a diagram.
