95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Dec 17, 2006 8:02 pm
by the way, if the planetary gears are stripped, the transmission would not shift into any gear, and the car would not move at all, as the planet gears along with the sun and ring gears do all of the transfer of power, and the transmission gear ratios totally depend on these set of gears. that is very very rare to happen as these gears are made very tough, chances are that the clutch plates in the auto transmission would be damaged long before the planetary gears...
as for the shifting problem, check your shif solenoids, i think that is a good way to start, and if it is only a problem changing from first, then most likely it is a shift solenoid, hope this helps, good luck
