truckmen »
https://forums.nicoclub.com/truckmen-u48663.html
Thu May 15, 2014 10:37 am
UPDATE:
It starts, with difficulty! But, I believe I may not need a starter.
But also found out that the catalytic converters were cut off (probably stolen) and I need to buy a pair of them.
Any ideas on reasonably-priced correct fits?
UPDATE (part 2),
The engine started and after throwing some fresh gas, got it to run steady. I discovered that this engine has a very loud "rod knock" sound. However, no "engine check light" comes on nor does the engine run all that rough.
I revved up the motor in park to ~2000 RPM and the "knock" speeds up in sync. As the engine drops back down to idle, the knock gets very loud during part of the idle-down. My spotty experience tells me that this is a rod knock. Could anyone concur? I know that oil pumps can also make a similar sound when they "go out".
Now, what I need to do is to find a way to determine for sure that it is a rod. If so, the question then presents itself:
Would you find a replacement motor or fix the current one?
