Figured I would update this thread with some research info since progress has been slow due to funds.
I've decided I'm going to build my own hybrid turbo. Not sure when I'm going to purchase it, as I'm debating on getting the car tuned and just enjoy it for a bit, or to get the new turbo and then tune it.
Currently I'm running a GT2871r 48 Trim
Compressor wheel: 49.2mm/71mm
Turbine wheel: 53.9mm/47mm
Exhaust housing: 0.64 A/R
My goal is 350whp with a little room to grow to 400whp if I get bored. I don't think I can achieve 350whp on this trim, I'll just be blowing hot air.
With that said, after hours and hours of research reading DSM, Land Cruiser, and Audizine forums, I've settled on the compressor wheel of the GTX2867 after learning to read compressor maps, compressor/turbine info and whatnot. I'm actually surprised that there's so few S chassis guys that run hybrid turbos. There's almost zero information on building a turbo for an SR20, and especially a CA18 obviously.
Anyways, the GTX2867 compressor wheel seems to fit my power goals while also not going up to a large compressor wheel like the GT3071R 54mm/71mm.
GTX2876 55 Trim Specs:
Compressor wheel: 50mm/67mm
Turbine wheel: 54mm/47mm
After reading through a Zilvia thread from Pure Turbo's back in 2012 when they were building hybrid turbos for people on Zilvia
https://zilvia.net/f/showthread.php?t=482023
I searched them out and was surprised they are still in business in SoCal. They recommended me PT Turbos in Los Angeles, as Pure Turbos doesn't do hybrids anymore, they're focused on the BMW kids with their B58s and s***.
After contacting PT Turbos and asking about the difference between the GT and GTX backplate bevel not being compatible, they said it was definitely possible to machine. Here's a example picture of what I'm talking about on the GTX wheel. The GT wheel is flat.
As for compressor wheel, the new one will fit with some machining of the compressor housing to fit a larger inducer. After some debating on blade count, it seems like 8+0 would fit my application the best. Apparently they also stock KTS wheels, which are one of the biggest and most well known wheel manufacturers in the world, as apposed to Mamba/Kinugawa that are made in Taiwan.
All in all, got a quote for upgraded billet compressor wheel, machining of the compressor housing and balance for much much cheaper than a GTX2867 brand new. Anyways, just thought this was interesting and will definitely be something I do in the future.
