Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat May 15, 2004 5:38 pm
you can leave the fan as it is, but you should put a 14", which is the biggest you can fit, on the front side of your condenser coils. Otherwise, you could do what most of us did and put a 10" fan on the front condenser coils and wire it to the existing a/c fan circuit as a pusher and put a 12" or 14" on the back radiator side and hook it up to a heat relay sensor as a puller.
