ive searched and cant find answer please help
ls1240
Car: 1990 240sx hatch
i have an 90 s13 hatch and i want this vlsd this guy is selling out of his 90 na 300zx i know the diff will fit but what i dont know is what are all the parts i neeed i need new half shafts are those axles? and will i have to have a 5 lug pattern? i really dont know much so any help would be greatly appreciated i wanna know what i need b4 i waste my money on something thanks alot :)
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Half shafts ARE the axles, and I'm pretty sure the splines from the 300zx half shafts (NA) fit right into the oem 240sx hubs. That means you can keep the 4 lug, but 5-lug is always an option to you. I'm pretty sure the R230 differential will require some subframe modification to fit (different bolt pattern).
ls1240
ahh damn what kind of modification? so i should get the axles from the guy also?
speedeast
I would get the axles if they're priced well. I bought my beefier tt axle for $68 shipped, and picked one up from a junk yard for $10. I had to rebuild a boot on each one, but the Raybestos boot from Rock Auto is only $9 right now, and probably for a limited time.
Don't quote me, but I think you can actually take the cover off of your 240sx open differential and bolt it onto the 300zx vlsd. If that's the case, then it would make life a lot easier for you. I don't know what else has to be done, I just know the R230 is bigger and has a 2-bolt design, while the 240sx has a 4-bolt. I used a Q45 differential with the cover from my 240sx diff... so I can only research and speculate otherwise. Good luck!
ls1240
Thanks alot man yeah Ive heard and read somewher that u have to change the diff cover I do change it will it just bolt in without any mods? Or the cover doesn't matter that much
