fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Mon May 02, 2005 8:30 am
Okay, thanks for searching first: these are good questions and the kind we should have more of around here!
A RRFPR/FMU rated at 8:1 will raise the fuel pressure 8 psi for every 1 pound of boost. Likewise, a 1:1 model - like stock - will raise the fuel pressure 1 psi for every 1 pound of boost. This would mean, assuming you have a base fuel pressure of around 40 pounds, with the 8:1 at 5 psi you should be around 80psi of fuel pressure (40 + (8*5) ). The stock fuel pressure regulator does in fact add more fuel as you increase load (boost), just 1:1 is typically not enough.
I have never heard any problems of a fuel rail actually bursting from too much pressure. The stock lines are fairly solid and, assuming all your connections are fresh, should have NO problem with whatever pressure you throw at it with a FMU/RRFPR. It is a metal line, even rubber lines can easially handle well over a hundred psi (check the raiting on the hose). This shouldnt be an issue for you.
Timing is kind of a funky thing that not a lot of people understand properly. The reason timing ever changes in an engine is because you always want to have peak cyl pressures at the exact right time, right at or just after TDC (top dead center). What this means is you want the mixture (air/fuel) to be exploding with maximum force JUST as the piston is about to start heading downwards on the power stroke. This would be simple to do if the combustion rate was constant at all times while driving, but its not. Fuel/air mixtures at different temperatures, different ratios (rich or lean), different octanes, and different pressures take different amounts of time to burn completely. An intake charge of air and fuel compressed to 8 psi will ignite and combust MUCH faster than a similar charge at atmospheric pressure: the mixture is simply more reactive and "ready to explode." Because of this, you need to fire the spark LATER (retard) as the piston is coming around towards top dead center... because the mixture burns faster you have to ignite the spark as the piston is closer to top dead center, which hopefully results in peak cyl presures excactly at the right time. Figuring out exactly how much later you need to have the spark fire to achieve the best power is part of the skill involved with tuning, but for basic applications most people simply suggest a roundabout amount of degrees to retard per pound of boost (around .5 degrees).
If I explained all of this well enough to understand, it should also be clear why ignition must be advanced (spark fired prior to TDC) when RPMs increase. Because your (non boosted) air intake mixture at a given temperature will take a fairly static amount of time to combust, as RPMs increase and the piston starts moving faster and faster, you need to start igniting the fuel EARLIER so as to get full combustion by the time the piston is at top dead center. Think of throwing a ball in front of a moving car. The faster the car is moving, the earlier you are going to have to throw the ball out in order to have the car hit it, right? Same idea here: you want to time when to start igniting the fuel, so that by the time the flame has spread and the explosion has the most power, the pistion is right at the top and ready to be pushed down by it. Again with the car/bar analogy... if you throw the ball harder/faster, you actually are going to have to throw the ball later as the car is closer to you, in order to time the ball + car hitting at the exact right time. Same deal with boosted applications and more volitile mixtures... The explosion happens faster so it has to be begun (ignited) later in order to achieve that perfect meeting point at TDC (or just after actually).
Detonation is when timing (for one of many reasons) is NOT correct. Imagine firing the spark too early, as the pistion is still making its way upwards towards top dead center. The force of the explosion of air/fuel is actually pressing downward on the pistion as it normally would, except the pistion is still trying to come upwards in its cycle. This results in a battle of pressures, and puts a lot of stress on the engine (specifically the rings on the piston)... The explosion certanly wouldnt be enough to reverse the direction of the piston, but the piston will suffer a LOT of damage from the mis-timed explosion. This is why knock is so bad in boosted applications. It takes mere SECONDS of serious knock to destroy ring lands, pistons, rods, everything. At 7000 RPM the piston is in its compression stroke (coming up towards TDC and compressing the intake charge) 29 times per second. On high boost applications like in race cars, you dont even hear detonation before the engine is completely destroyed. The timing goes out and thats it, boom.
This is why people put so much effort into making sure the timing is right even in lower boost applications. Also higher octane gas helps (the higher the octane, the SLOWER the mixture will burn, allowing timing to be advanced a little - or in our case - retarded less), as well as alchy which does much the same thing.
Okay okay, I'm done typing now. Hopefully all this helps you. If you are confused about anything please feel free to ask. I or someone else around here will be happy to help. Again thanks for taking the time to search, and THANK YOU for being one of the few who is actually trying to wrap your head around the concepts before you go shopping for parts. Keep up the good work and good luck!
