alright... so new developments... my "screech" turned into an exhaust leak... a big one... looks like it was just whistling out of the gasket between the header and the turbo when one of the four studs snapped.... so then it got worse, and started shaking loose the other three... then the exhaust leak... then hobbling it home, it got drastic and blew half of the gasket out... SOOOOOOooooo... ive got some work to do in light of needing to locate another gasket for replacement... i went down to my local napa auto parts store, and got replacement studs, nuts, and lock washers... but they had nothing for me when it came to the gasket. looking into it, some simple gasket maker wont do because of the extreme heat, and stamping one out myself isnt an option because i simply dont have the tools or material.... so what is it that you nissan techie guys recomend? below is a picture of the problem.
i was also looking into buying a header for the car... i figure i can get one with a legit gasket as well... something that looks cool for the sr20det, and is functional too... any recomendations?
