boost_boy wrote:Man, you are getting a serious work-out with your motor. I'm sorry you're having all these problems, but if the cross harches on your cylinder walls were missing, your engine is not only out of balance, but your cylinders were possibly out of round. The machine shop that's doing the work should exercise extreme caution by following the specs or you will be tearing this thing down again.
Why is that a sign of cylinder out-of-roundness, or unbalanced rotating assembly? If the hone pattern is missing, doesn't that mean the engine is broken in? (hopefully, at least... in any case, the break-in window is gone)
float_6969 wrote:Yea, if they didn't follow the clearances, that could cause a lot of problems. The CP's especially expand A LOT when they heat up. My motor is REALLY noisey until things get warmed up. One (of many) reasons I don't take it on short trips, and I let it warm up for a few minutes before I start driving it.
Mind doesn't shut up even when it's warmed up. The sound it makes is very close to what my 1.5 diesel DD makes normally. Heard another CA built with with CPs recently at a meet, same thing. Don't know his clearances, but mine were correct, on the loose side of the range, though. God, that sound's really unsettling.
