jrb92se »
https://forums.nicoclub.com/jrb92se-u35859.html
Sat Nov 18, 2006 7:55 am
s13 rb25det: so ive been kinda smelling warm oil in my car occasionally, at first i thought it was an exhaust leak but upon further inspection i found that my stock turbo has some fresh oil on the center section, it appeared to be leaking from aroun the return hose to the block and it was .....BUT..... it was also seeping from around where the compressor housing and center section are connected; below is a pic its not a close up and i had wiped most of the oil off already but it gives you an idea of the places it was leaking from. its not pouring out oil or anything , ive never had an low oil issues and it never really smokes, so i tightened the bolts on the return a little and it isnt really leaking there anymore but it still has some seeping from around the housing, it still spools fast and holds boost (although i have recently started noticing slight creep high in the rpm range).i think that this turbo has been going since i got the car because i never really thought it was as fast as it should be, so now im gonna get a new turbo, manifold and injectors ive read a bunch of threads saying that the gt30 garret turbos are the best for this engine, but martin at xat strongly recommended the gt35, he also told me he knows there are people using a certain type of ebay manifold without problems he said it was around $200 and placed the collector on top between cyl 3 and 4 anyone know which one hes talking about, i dont trust ebay but he says that they work good so im willing to give it a shot. im gonna get a set of deatsch works 555s and prolly a tial w/g, all appr. lines fittings etc.. im also getting 1300 bucks for body work from this guys that hit my cars insurance !!! so im basically going to be getting a whole new car in the next few weeks!! anyone want to make any suggestions for the new setup / paint scheme (two tone white and bronze maybe)....
