Its the little things im worried about...
dmora
I want to do an RB conversion, but baring the obvious difficulties, what are the little things most people forget to thing about when transplanting?
Speedo? tach? Temp gauge? gearing/transmission swaps?What other things would someone easily over look in these cases?:confused:
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
The condition of the engine, with the engine on the ground its much easier to check all the rubber water lines and replace them with new ones, Replacing the front and rear main seals changing the timing belt and the water pump, get wild and put a metal head gasket on.
dmora
YamaOni wrote:The condition of the engine, with the engine on the ground its much easier to check all the rubber water lines and replace them with new ones, Replacing the front and rear main seals changing the timing belt and the water pump, get wild and put a metal head gasket on.
engine work will be taken care of my friend building it. Im not sure which engine im gonna use just yet. uesd R33 block, or new R34 or Nur block.
