Its spring time pimpin pics (56K warning)
driftfan420
I just finished washing up my car and went to take some pics. Man, the only bad thing is i hit quite a few bugs on the way to take the pics.
E7-S14
Car: ess 14 foo!
camera takes great picswhat is it?
Nice car.15mm spacer back 10mm spacer frontand your straight!
AZ89two4Tsx
Sweet Ride! Very Clean!
SR right?Btw, where did you get your tailights? Haven't seen those before.
E7-S14
Car: ess 14 foo!
AZ89two4Tsx wrote:SR right?
No
AZ89two4Tsx wrote:where did you get your tailights? Haven't seen those before.
They Don't Exist
driftfan420
i took the pics with a Nikon D40x. As far as the wheels, I'm going with a set of Zeforged wheels so no spacers are needed at this point. I'm trying to model the car like the 280Z on the website. Check it out in the gallery. ZEforged.com S15 front, in the same grey as that 280.
driftfan420
I got the tails from one of our sponsors. http://www.ravspeconline.com/shop/catalog/ . they had a set of Dmax tail lights on their site that looked pretty sick.
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
very clean car! that engine bay is pure sex! i love it!
freakyjason
Car: 1990 240sx
Wow! Very clean! Are those megan seats i spy? If so, how do you like them?
frenetic
Car: 1993 240sx Coupe
Another Oregonian! wee. Nice ride, clean as hell. Have you eaten dinner off the engine yet?
...nah that would make it quite dirty I guess.
S14toRPS13
Those dmax are sexy! They look really good on your car. I'd like to know your opinion on those megan seats alos. I'm saving for some east bear but if those seats are decent, I might go for them.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
those tail lights are sexy. i might take them up too in stead of soem koukis
Nissan240sx_s13
Car: 1990 Nissan 240sx
wow that made me actually lol. Anyway clean car, its amazingly perfect...
E7-S14 wrote:
No
They Don't Exist
Nissan240sx_s13
E7-S14 wrote:
No
They Don't Exist
E7-S14 wrote:
No
They Don't Exist
sttp01
is your right rear quarter panel all banged up or is that just the reflections playing tricks on my eyes, if so that is a shame to happen to such nice paint. Cool Pics.
kernan240sx
Car: 89 240sx
very clean ride. And your from OREGON!!!!
driftfan420
The megan seats are decent, they hold you in pretty firm. I can't complain... I want to switch over to the Sparco Evo XL seats, so if you're in the market they're yours. as far as the lights, everyone has the Kouki lights, so I decided to go a different way. I'm thinking of putting LED's in them. The way they are, I think the LED's would really set them off. It already looks kinda like they're LED just from the patterning of the lenses.
Lastly, no your eyes aren't playing tricks on you. Me and the garage were playing tag..... I guess you know who's it.
spooled240
Car: kouki s14
I like those tail lights! Very clean and different at the same time. And that's not a sr??? It even looks like the sr valve cover just w/o the "turbo intercooler" words on it.. Regardless, looks really clean and done right
driftfan420
Its a SR. redtop... just doesn't have the coilpack cover on it.
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
nice bay pics.. IMO if u ditched the black "tape" around the car, and got clear lenses for blinkers and marker lights, it be even sexier.
but good work, what kinda power is that sr putting out/what are u running for parts, psi ect..
taco_401
Car: 240sx
its nice all around
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
I might have missed it, but where were these pics taken? Looks familiar..sort of oh and your car is BOSS btw.
White Comet
Car: fc, s13 and mazda6, Sierra
looks great. i approve on everything
driftfan420
Pics were taken on the Historic highway, in the gorge.
the car was dyno'ed at 349whp on mines ecu. When the haltech goes in, it will easily make 400 or close to it. A shop chopped up my wiring harness, fired the power wire to my ECU and then had the nerve to say it wasn't a fault with their wiring. I'm a Engineer, so electronics isn't something you can BS me on . Besides, the car had been running for 2 yrs prior to this no issues at all.Oh, and they wired it incorrectly so i wasn't able to install it because the haltech doesn't boot up in correct sequence.
Drivetrain:
Nismo Engine/transmission mountsACT Heavy Duty 6puck sprung clutch Torque Capacity: 463 ft/lbs.Nismo steel braided Clutch lineVLSD2. Nismo Slave Cylinder and pivotFidanza lightweight fly wheel/ Fidanza Friction plateShaftmasters One piece Aluminum drive shaft W/ drive shaft safety loop
Suspension:
Tein super street CoiloverSuspension technique sway barPeak Performance Urethane Subframe BushingsTanabe Sustec Strut Bar front/rearNismo Power Brace S13Nagisa Shakitto Shock Tower Plate 240SX '89-'94 (not installed)Tanabe fender brace (not installed)
Braking Power:
Brembo slotted brake rotors ( Stock 240sx 4 bolt pattern)Hawk break padsAgency Power Stainless Steel Brake Line Kit Stock FrontAgency Power Stainless Steel Brake Line Kit Stock Rear
Engine Upgrade:
Top end:TODA SR20DE(T) Intake camshaft 264/10.5mmTODA SR20DE(T) Exhaust camshaft 264/10.5mmFerrea Dual Valve Spring Kit for Nissan SR20DETFerrea Valve seatsFerrea Titanium valve retainersPort Flow Manganese-Bronze Valve Guide SetBrian Crower Exhaust +.5 Valves for SR20DETBrian Crower Intake +.5 Valves for SR20DETER Spec Stainless Rocker Arm StoppersCometic 1.1 87mm metal head gasket,Copper Exhaust gasket,Metal Turbo Gasket,ARP Head studsBottom End:
-CP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware.-Main Bearings-Crank Bearings-Thrust Washers
Fuel System:2 Walbro 255 Fuel pumpsTomei 740cc InjectorsZ32 Fuel Filter Nissan SR20DETNGK Iridium Spark Plug Set for Nissan SR20DET (Heat 9)Sard Fuel Pressure Regulator hose type fittingLiquid filled Fuel Pressure Gauge
Power Upgrade:Garrett gt2871R turboTaka S13 SR Bottom mount Turbo Lines:w/Taka Ball Bearing Oil RestrictorGodspeed intercooler w/ custom intercooler pipingHKS ssqv BOV w/ custom pipingGreddy intake plenium (polished)Snow Performance Stage 2 Methanol KitTomei exhaust manifold (heat wrapped)Tomei exhaust elbow
Engine Cosmetics:
Flex-A-Lite model 345 Dual fansPower Enterprise Super V-Belt (Kevlar) S13SR-Belt-Set/Main,P/S,A/CGreddy SR20DET Oil PanMegan Racing S13 SR20DET Light Weight Pully SetSamco hoses ( radiator, couplers, etc.)Greddy Oil Filter Relocation Kit for Nissan S13 SR20DETMA powersteering custom line (powersteering line)Color BlueMegan Racing 1 3/8 water temp adapterCircuit sports polished coolant tankKoyo RadiatorNISMO SR20DET Grounding kit(4 Gauge)
Interior Upgrade:
2 megan racing reclinable seats2 megan harness CUsco Custom 4 Point Roll Cage w/ harness bar Nissan 240SX S13 91-93 ( scheduled for fab and install)Roll Bar Padding - SFI Spec 45.1 Rollbar PaddingATI EZ-Pod : S13 89-94 240SXCarbon Fiber door panelsMomo Stealth foot pedalsMomo Stealth FootrestMomo Aluminum grid floor matMomo Floor matsMomo shift knobMomo leather shiftbootMomo stealth EbrakeMomo Ebrake leather bootMomo GTR2 steering wheel (not installed)NRG Gen 2.5 quick release adapter (silver)Splash short boss Steering Hub (not installed)
Gauges/Controllers:
Haltech E8 ECU w/ Map sensor(not installed, running mines ecu)Air temp sensorDual stage shift light (not installed)Coolant temp sensorGreddy Turbo TimerAEM Uego (Wideband)AEM TRU-BOOST Gauge-Type ControllerSaga Technik Gauges (fuel pres, oil pres, oil temp, water temp, Boost )
Audio: ( not installed in garage until time for paint and bodykit install)
2 8” Rockford fosgate sub2 10” Rockford Fosgate Sub2 6 1/2 “ Kicker door speakers4 Kicker 100watt dome tweeters1 Rockford fosgate P-400 amp1 Rockford fosgate P-200 ampCustom sub enclosure/ amp rack Kenwood deck w/ USB connection
Exterior:
Dmax crystal rear tail lightsNew Wheel well inner cover
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
If I pay you, will you install a p*ssy magnet? No really that car is beautiful... Except im not to into the whole polished cover thing... If the head were painted then it would be cool.
wackawacka
E7-S14 wrote:
No
They Don't Exist
Harsh... Funny, but harsh.
spooled240 wrote: And that's not a sr??? It even looks like the sr valve cover just w/o the "turbo intercooler" words on it..
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
Very nice car! Super clean and shiny! Looks like you've had some fun modding it too. The only thing I'm not feelin is the wheels, but to each his own.
project90
Car: 1992 240SX fastback
another northwest 240, looking nice!
S14toRPS13
driftfan420 wrote:The megan seats are decent, they hold you in pretty firm. I can't complain... I want to switch over to the Sparco Evo XL seats, so if you're in the market they're yours. as far as the lights, everyone has the Kouki lights, so I decided to go a different way. I'm thinking of putting LED's in them. The way they are, I think the LED's would really set them off. It already looks kinda like they're LED just from the patterning of the lenses.
E-mail me about the seats.
sommmatt
Car: 1989 Nissan 240SX
DO WANT
nwmrkt
Car: S13
can you give more info on this?
"CUsco Custom 4 Point Roll Cage w/ harness bar Nissan 240SX S13 91-93 ( scheduled for fab and install)"
What exactly are you doing thats custom? Reason asking because im looking for a 4 point to and id like to see all options.
Sounds interesting.Thanks
