carmo »
https://forums.nicoclub.com/carmo-u91933.html
Mon Sep 08, 2008 7:32 pm
I'm confused. So you didn't have a problem with the thing until you put a new clutch in it and had the flywheel machined? A machine shop would have to screw a flywheel up pretty bad for you to not have a clutch any more. So from the back of the crank shaft you have your flywheel bolted. To that, you install you clutch disk and pressure plate using and alignment tool. From there, you have your throw out bearing and fork (with the little metal retainer clips for the bearing). The only thing left is the hydraulic system. Maybe your confusing partial slave cylinder throw for full slave cylinder throw? Tell me more.... interest is peaked.....
