ITS IN!!!!!!
burntricer
Car: 90 S13 SR20DET Redtop
but ive got no power anywhere
i cant turn the headlights on, i have no power to the radio ect,
we dont touch those things when we do the swap right? so im assuming its my battery....
ill update when i take the battery off charge,
johngriff
Car: 240sx
Do you have a good Ground on the battery? Test the battery with a multimeter!
burntricer
well it cranks now, so thats all good
burntricer
it cranks, but thats about it, i gotta find out why it wont fire, ive got all the wiring in, but i found a cut wire, its blue with a red stripe....and i cant find where it goes or what it plugs to, im pretty sure thats part of the problem...
capowered240
Car: 90 240sx
Where is that blue w\ redstripe at? Is it on the upper (main ) harness or lower harness?
nissanic89
Car: 89 nissan coupe
blue red stripe, isnt that the fuel pump wire?
ca18det240hatch
if its the BIG blue with a red stripe in teh main harness, thats ignition power i believe, it leads up to the coilpack harness ultimately.
burntricer
thats exactly where its cut, does it just need key on power??
burntricer
it obviously doesnt need just key on power, i tried that and got nothing, i gotta do some investigating tho,
does the wire need to go to any relays or to the ecu??
capowered240
Car: 90 240sx
yes, it is for ignition power. So it is cut up by the coilpack harness?
burntricer
yep
capowered240
Car: 90 240sx
you've got those 2 brown and gray plugs behind the battery wired correctly?
burntricer
yep as the SR guide says, like i said its cut at the coil pack harness
capowered240
Car: 90 240sx
This should help you out. it's the wiring diagram.
http://www.impactblue.org/cont...agram
burntricer
k, ive got good spark, but no fuel now, im using the DSM resistor...
capowered240
Car: 90 240sx
alright, is the fuel pump coming on? If it is then make sure you don't have you fuel lines crossed. Do you have a fuel pressure gauge?
ca18det240hatch
best thing to diagnose that no fuel situation as well is to get a friend to crank the car while you do this.....
take a screwdriver, put the bit end on the injector, and the other end of it in your ear, and it will amplify the click that the injector makes so you can tell whether its firing or not.
should be a rhythmic clicking.
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
another quick question I have an injector resistor out of 1st gen dsm does it clip right into the harness or do i have to cut and splice???
capowered240
Car: 90 240sx
Cut and slice. That's what I had to do. It works just fine.
burntricer
no fire from the injectors whatsoever, the dropping resistor from a DSM...
davidricardo86
Car: 1992 Nissan 240SX SE
burntricer wrote:no fire from the injectors whatsoever, the dropping resistor from a DSM...
I had this same problem. I had spark, fuel pressure, and was cranking but it would not run on its own. We then used a stethescope to hear if the injectors were clicking and the werent. There is a red wire that goes into the resistor. This red wire is suppose to get its power from either the ECCS or ignition relay and supplies power to the injectors.
Bascically this is how its suppose to go:
battery - ignition switch - relay - injector resistor - injector- ground(computer controlled)
burntricer
ya well, now i my fuel pump wont come on unless i ground it, man i need a new harness!!
Red93coupe
capowered240 wrote:Cut and slice. That's what I had to do. It works just fine.
-Where am I supposed to cut and splice then I have no clue??
capowered240
Car: 90 240sx
Just cut the plugs off and connect the wires. On the harness side their are five colored wires and on the dsm resistor pack their should be 1 white wire and 4 black wires.
Connect the red wire on the harness to the white wire on the resistor pack and the other wires just connect them together. I don't what everybody else did if they are using a dsm resistor pack, but this is what I did and it works no problem.
