rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Thu Nov 01, 2007 12:54 am
The easiest and quickest way I found to do this is pull the slave off the transmission, Leave the lines connected and have someone pump the clutch while you hand bleed it, Almost like bench bleeding but you leave it on the car, Do this a few times till the slave is pumping all the way out, re-install and bleed it a couple more times and it should be good.
I have worked for hours on trying to bleed it before, This seems to only take 30 mins or so, Maybe not that long, My prob is My twin plate cusco exedy clutch is so damn hard to push in, The slave doesnt have enough travel to push the air out before it overloads its self, Bleeding it off the transmission fixed my prob.
