Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Sun Jan 17, 2010 5:29 am
If it's not giving warm air, it's often the thermostat that has failed. I see this in our shop all the time when winter rolls around. Run the engine and see if the top hose gets hot when it's cold outside. Does your temp gauge show about center on a cold day when the engine is warmed up? Does the gauge drop a lot when driving when it's cold out? The gauge should stay in the center no matter what the temp is outside. If not that's a pretty sure sign it's the T-stat.
Fan shroud, top rad & bottom hose off the pipes, T belt covers preferably and coolant pipes have to come off. It's easier if you take the rad out for more working space which is only a couple extra bolts and the lower hose. The pipes use nuts and Allen head bolt holding it on and is fairly hidden so make sure they are all off before you try to remove it with force or it will break. Also, only use a Nissan thermostat. Motor Rad and a lot of after market ones are crap and will fail in short amount of time. The few extra bucks is worth it.Make sure you clean the pipes well so the connector hoses will seal and replace the 2 short connector hoses with new ones.Not a huge job but a few hours for sure. If not that's likely the issue.
Good time to do the T-Belt and water pump if it hasn't been done.
*Look just below the center top idler pulley and you will see where it belongs
Modified by Zwicked at 7:43 AM 1/17/2010
