Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sun Feb 19, 2006 10:52 am
Now i have a few other problems now that i've been driving more, Since its snowing. I was going up a hill last night and my wheels got just a bit of wheel hop and i heard a loud knocking noise.... and going back up that same hill i heard it again. It sounded like a loud rod knock, it did it like 2-3 knocks both times, and that was IT, it hasnt done it since. ( One thing i'd like to add, is that my bell housing sits up against my firewall quite well and my starter is extremely close if not touching on the other side. ) My car drove fine, idled a little high like it always does, and decelled and accelled perfectly fine like it always does, So im thinking it was just the entire driveline shaking.
Another problem is... i can hear the TO bearing in the transmission, its pretty loud and i can hear it clack when i back out the clutch and then when i press it in, it doesnt make any noise at all. The TO bearing is brand new and i did install it right.
My transmission seems to be pretty loud as well. Its got a pretty good whine to it, and it makes alot of noise under 2000rpms when the engine is low and kinda bogs like most do. Sometimes my Reverse is really damn loud and then sometimes its quiet. When im normally driving its quiet and doenst grind at all though.
I used 75w-90 synthetic transmission fluid. The driveshaft i made, i think might possibly be too short. the yoke is about 6 inches long and about 3 or 4 inches goes in, do you think transmission fluid could leak out of there?
also something i forgot to mention, my oil pan sits either ON or rediculously close to my sway bar.
Modified by Kansei240sx at 1:05 PM 2/19/2006
Modified by Kansei240sx at 1:13 PM 2/19/2006
Modified by Kansei240sx at 2:15 PM 2/19/2006
