MoldyOldy240 »
https://forums.nicoclub.com/moldyoldy240-u41784.html
Sun Dec 10, 2006 10:35 pm
Haha! I just put my DE in the engine stand for a major overhaul and upgrade! Pics coming soon, I'm just very excited as this is my first engine, and to me its a huge step in a great direction!
Little background on the engine: It had a vavle drop in the number 4, but it still ran supposedly, its also though been through some brief sprinkles witch the vavle cover off...(SD weather is weird). I obtained the thing for $125; I figured since I'm replaceing the header, cams, pistons, rods and vavles, it would be worth it. The goal with this engine is to have 200+ trq NA; keeping in mind after this build a FI componet will be added, so it has to stand up to that. End result should be interesting of this first NA build of mine.
I had to go to ace hardware to obtain the correct bolts (4 M10 - 1.5x70); they are only grade 3 (lowest grade there is but its enough for this application.)FYI- grade three has no notches or lines on the head of the bolt. 4 has 1 notch, 5 has 2 and 6 (the strongest you can get other then aircraft grade which is a whole different system) has 3. There are a few other sybmbols which relate to different things, but I do not have that information in my head.
ANYWAYS
