SSS »
https://forums.nicoclub.com/sss-u3929.html
Tue Jun 03, 2003 12:07 pm
ITB's WILL make an immense difference IF they are tuned correctly. For example, RPW here in Australia did an ITB manifold (using the standard runners, see pic HERE) on a 1.5L SOHC 12 valve Hyundai excel. the car made 87hp standard at the flywheel, and with headers(4-1)/catback, the ITB's, a standalone computer, cam and ported heads, the car made approx. 150hp with more tuning to follow. 180hp is not out of the question, and this is a 1.5L with a std bottom end.
Why i bring this up, the head on this car is essentially similar in design to the KA24E head, albeit the KA head flows better. I will be utilizing a similar setup on my KA sohc motor with the following already installed: 262/264deg cam, headers (4-2-1), ported heads, increased compression (8.6->9.0:1), all on a standard bottom end. When the ITB's go in, a piggyback computer will handle fuel/timing. I will be aiming for 175hp at the wheels. (and no, the car isn't a 240sx, it is a 1992 Pintara TRX, a better looking version of the Stanza):D
