If the fuel pressure is that low, then I will. Had a larger fuel pump in mind already. Vacuum doesn't have me worried, I can get all of that to work and when I do this I'm going Megasquirt and dual Ford EDIS.seang wrote: The Z24i only has about 6psi fuel pressure stock. You might have to install a different fuel pump. I personally don't know about the vacum diagram setup, Brake booster, vacum advance. Needs a M.A.P. sensor for sure. It would sound really good, like webers. If your particular truck isn't a rust bucket like my 87 was.
You know, the dual plugs have had me worried, too. I wonder if I shouldn't find a non-NAPS-Z head.seang wrote: Be careful not to run the dual plugs too hot. Under full throttle only one side works anyway. Maybe you should try dual colder ones, but honestly, its just a gut feeling. Don't colder plugs allow you to advance the timing more?
Why do you think my mileage will be better if I stick with the dual plug?seang wrote: I would try the dual plugs, but a bit colder, and with less advance at first, and then advance it a little bit more until you reach the sweet spot. I bet you will get good mileage that way. what have you got to lose, because a different head is a whole other story. And even if you do decide to get a different head, you can always transfer the itb bits to that one later on.
I just thought about this, doesn't my Throttle Body Injected Z24i have more than 6PSI of fuel pressure?seang wrote: I guess different combustion chamber technologies disprove the dual plug design, or at least simplify.
Huh, but then again TBI is somewhat like a carb, so it doesn't surprise me that much.seang wrote: I'm pretty sure it's between 6 and 9psi for the tbi version, much less than a port injection system. I realized this after buying a ZEX nitrous kit for my old 87 d21 with the z24i and 5 speed. The kit specified at least 36 psi to work right, so that project never came to be.
Well, guess that just confirms I will need another fuel pump. One from a KA powered car should do fine, as I'm not really looking for a ton of power (170 would be nice, but I'm probably mostly dreaming).nismopu wrote:yeah, I just checked the clymers manual and it does show 14psi max for the tbi systems. I guess thats why the fuel pumps are so different. peace.
