ITBS for my turbo KA?
tigwebu
Car: 1993 Nissan 240SX Convertible
I'd had my last question about itbs, if I'm using a plenum and TPS(750) from the ITBS/ 300zx MAF can't I just use a EMS like safcII or emanage?
tigwebu
OUCH!!!! 36views and no answer , not even for WD, maan..... no NICO love.
NateDogg
You can use either of those if you are using a MAF setup.
tigwebu
NateDogg wrote:You can use either of those if you are using a MAF setup.
i have safc II, haven't used it just collecting dust. But doesn't that need both TPS and MAF to run. If so would the TPS for suzuki(ITBS) and maf from nissan work? I guess does the TPS from the ITS work or does it have to be modify to work.
tigwebu
hmmm. safcII is universal, right, so it would be able to read the TPS from the ITBS.. .also TPS are universal to just are modify to fit there application but the electronics or system is universal. right
Modified by tigwebu at 1:27 PM 4/24/2007
WDRacing
Most TPS read in .05v to .5v. The SAFCII is univerals and can most likely be used. Although with a nice setup like that, why go with a SAFC?
tigwebu
WDRacing wrote:Although with a nice setup like that, why go with a SAFC?
Home project, with my car coming out of the storage building and coming home I have more time. So I wanted to do something wild. Plus its cheap I have everything except coupler with wires in them and clamps.
Chezedik
Car: 1991 Nissan 240sx
Dig it. If the Suzuki uses a 5v ref TPS, then you can use emanage to tune it. But it may be a long road if resolution is not similar.
ace0073
Car: 1969 datsun 510
OR......you can just modify your stock TPS to fit onto the ITB setup, which is what i plan to do. i have an article somewhere that explains it. I will look tonite and hopefully post it tomorrow. i believe doing it this way also makes it so you can use your stock computer. i will know more when i find the article; if i find the article!
Chezedik
DO IT NOW! And when you do, this needs to get stickied.
ace0073
LOL....im still at work but im on it, BOSS!!!
Chezedik
Boss? I like the sound of that...
turbo_dreams
Car: 92 240 sx hb w/ 120k miles.
Where's the write up ?
Chezedik
I still wanna be BOSS.
Chezedik
Where are these pics?
Numby
Car: 92 240 sx
Wheres my cake *****
Chezedik
Topical and relevant, very nice.
