SimpleEnigma wrote:The major thing you would see upgrading to ITB is the throttle response.
In my experience, throttle response was not significantly improved. It's not something you can measure, so it is hard to call the issue. In running my ITBs for nearly a year, I never once had a OMG moment cracking the throttle. You'd find bigger gains with lighter rotating components.
Granted, this was using the stock ECU and its timing maps, air/fuel ratios verified via WBO2. I'd imagine there would be gains if you rolled your own fuel and timing maps.
A34D4ME wrote:If I'm not mistaken, the stock intake manifold will already flow more air than necessary for most modestly built N/A motors.I'd also assume that any other potential benefits would be lost when reducing to one MAF.I'm curious though, ITBs are cool but what exactely would you hope to accomplish with them?
My experience has been that the stock intake manifold is not a restriction for KAs with bolt-ons.Most OEMs that use ITBs (BMW M-series engines, Nissan GTi-R and GT-R, for example) use plenum-based ITBs. The plenum doesn't detract from the advantages of ITBs, which is what I assume you mean by "reducing to one MAF." There remain individual intake tracts, throttle plates, and reversion pulses.
ITBs are cool, and they look bitchin'. Beyond that, it was an experiment to see what was what. If ITBs gained significant power. If the stock manifold was a junky piece of...junk (as it is stereotyped on most 240 lists). If I could make the setup work.
