Using the ka24e original ignition system with the MS is not an option at this time. You could modify it internally to work with hei or similar, but you would have to research and figure out how to do it (
www.msefi.com). You also have the option of utilizing an older nissan ignition system, like a z20 200sx electronic, or even vacuum advance. Tons of ways to accomplish ignition. The advantages of the edis escort system is that its cheap, superior, and many use it with mega so easy to wire in and work with.
On the ka24e, you cant really modify the oem manifold like you see the de guys doing. The runners drop basically straight down after the flange (if your thinking about it backwards anyways). If you want to start with an oem manifold that you can work with, find a 90-92 stanza ka24e manifold. The runners come straight out which would work well with ITB, but the water neck must be modified as it points in the wrong direction (will hit PS pump).
With megasquirt you can calibrate to use any tps that you would like, as long as it is potentiometer type (most are). That includes nissan oem and the suzuki bike ones.
everything else you can find by searching around this forum, have fun!
