djsilver »
https://forums.nicoclub.com/djsilver-u28622.html
Tue Dec 20, 2005 10:56 am
I've got some Hayabusa throttle bodies and a project in mind...,If you feed your ITB's from a common plenum with the MAF mounted on the inlet and the TPS mounted on the ITB throttle shaft it should work. Of course you'll still need to figure out how to use the Idle Air module if you want it to work with the stock ECU and idle properly. You might even be able to use the swirl control valve solenoid to control dual-length runners!....,
