Well, I’ve been researching doing an ITB setup on my KA24E. Here is my information and some questions....
ONE:TWM uses 45mm and 48mm TB’s for inline 6 BMW’s.
http://www.twminduction.com/Th....html
A BMW M3 engine is a little more than 3 liters. I’m not 100% up to date here but my point is even on the smaller engines BMW manufactures TWM uses 45mm TB’s. We’re talking 6 cylinders here. Each cylinder is smaller than one of the 4 found on a KA and they are delivering, roughly, the same amount of fuel delivered by a Suzuki TB’s to each of these cylinders. Money aside, doesn’t 50mm seem closer to appropriate for KA’s?
TWO:TWM also makes a universal fiberglass plenum which, they claim, really helps FI engines with ITB’s. However it can’t be pressurized.
A brand known as Golden Eagle makes an aluminum plenum for ITB’s but it’s shaped like a shoe box and therefore can’t be good for airflow.
The plenum would quiet the intake noise and give a somewhat stock look to the engine bay which Johnny Law might appreciate (Read: not notice).
I haven’t heard this anywhere else. Does anyone have experiences with ITB’s with and without plenums?
THREE:“Original equipment EFI systems are configured to meet very stringent emission regulations and to provide "soft" driveability characteristics. Positioning the injector as close to the inlet valve is beneficial in this respect. Maximum power however, is usually obtained by moving the injector away from the inlet valve, some racing engine manufacturers going as far as to mount the injector high in the velocity stack and others installing two injectors, designed to operate at different RPM. When TWM designed the throttle bodies our engineers were not in favor of having high pressure fuel on the atmosphere side of the throttle plate, although this could have resulted in some power increase. We compromised by mounting the injector as far from the cylinder head as possible while still maintaining the safety afforded by keeping the fuel downstream of the butterfly.”-
http://www.twminduction.com/faq/faq-FR.html
Has anyone considered using injectors designed for the donor bike? This would place the injectors closer to the throttle bodies and presumably make more power.
This guy…
http://www.gixxer.com/ubbthrea...21524…says the 01 and 02 gixxer 1000 injectors are 280cc and good to 224 horsepower. That’s the only information I’ve found so far though.
Would there be problems getting the Nissan ECU or a standalone/piggy to work with the Suzuki injectors if they’re big enough?
FOUR:A person could carb their engine. Here is what Tim Suddard, owner and editor of Grassroots Motorsport Magazine, has to say.· “ The extreme accuracy of fuel delivery by the ECU, at any load or RPM, provides the engine with air/fuel mixtures that fall within a tiny window of accuracy required for maximum power, or maximum economy.· EFI systems are not subject to the usual fuel surge and frothing associated with floats and float bowls in carburetors. One of the limiting factors in race car lap times has been the ability of the fuel system to deal with G forces. Gravitational forces in both horizontal and vertical planes have no effect on EFI systems.· ECU control of air/fuel ratios allows racing engines to safely operate nearer to the “ragged edge”. · PC programmable EFI can easily be adapted to suit future engine modifications as a vehicle evolves. Adjustments to fuel and ignition curves being as simple as making a few keystrokes on a PC. · EFI generally permits greater flexibility of intake manifolds designed to achieve higher inlet air flow rates and consistent cylinder to cylinder air/fuel distribution.· More efficient, higher compression ratios are usable, due to accurate fuel metering. This is especially the case with EFI units incorporating ignition control.· When converting to forced induction, turbocharging, or supercharging, EFI will enable the user to program boost-relative enrichment easily, usually leading to substantial power increases as a result of accurate fuel delivery.· Most EFI systems compensate automatically for changes in altitude and ambient temperature. Calibrating a fuel system for a specific race venue is hardly necessary with EFI, if adjustments are to be made, a few keystrokes on a PC are all that is necessary. · Some EFI systems also have a provision for a cockpit-mounted mixture control with which the driver can vary the air/fuel ratio. TWM's HALMETER AF30 is particularly useful for this purpose, providing a visual, onboard read out of the air/fuel ratio with its 30 LED display. · The solid state electronics in EFI systems are not susceptible to the mechanical failures associated with carburetors. Tuning parameters remain as programmed, with never any need to adjust for wear.”The above list was actually found at
http://www.twminduction.com/faq/faq-FR.html.
Note: I copy and paste real good.
Even without his information I really don’t see a reason to carb an engine when it’s already set up for fuel injection. With a plenum the MAF system could be utilized and the injectors could even start in the stock position for budget purposes. At the moment I don’t think I could carb if I wanted to because I haven’t seen any setups for sale. I’ve seen plenty of pictures of them and heard of some carbed race cars though. Any reason big money race cars run carbs?
Thoughts? Inputs? Advice from more experienced people would be appreciated.
I may ebay this set of Hayabusa TB’s.
http://cgi.ebay.com/ebaymotors...10066 Whatchya think?
Modified by Veriest1 at 1:13 AM 12/28/2004
