have you guys sync'ed your throttles? You should be able to get some more power and smoothness out of them if you haven't.
At the bottom of each throttle there should be 2 tubes, one you connected your MAP sensor to, the other has a rubber cap. Take the caps off and connect it to a carb syn tool. There should be a screw adjustment on the throttles to adjust idle on each one, then a master idle too.
They're pretty much like adjusting carbs,
I'm getting ready to sync the throttle on my bike, and just thought I'd see if you guys had taken the time to sync your throttles too, it's kind of an easily overlooked kinda thing.
--Justin
