it wont go in to gear??!! help
skylet414
Car: 1993 Nissan 240sx
like a week ago my little brother was drivin my 93 240 n then later he called me n said it wont go into gear.. so i asked around n got lots of different answers but im not completly sure. so plz any advice would be nice. also well if u step on the clutch like half way to about 75% itll go in to gear but sometimes it hard to do it n sometimes it goes in smoothly.. advice and help would be greatfull thanks
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
You need to check your fluid level in your clutch master cylinder and if it is low you have a leaking master or slave cylinder.
skylet414
its full, could it be anything else, plus if it was that then wouldnt the clutch peddle be on the ground?
Modified by skylet414 at 3:25 PM 3/17/2010
Spanky37
Car: 1993 240sx fastback s13
is there the same amount of pressure on your pedal? as it was when you could go into gear?
skylet414
yea its the same. my buddy told me that it might be because of one of the plates in the transmission, not the clutch, flywheel but the pressure plate,any suggestions?
Modified by skylet414 at 8:30 AM 3/18/2010
Spanky37
it could be your pressure plate. the best way is to just take out the transmission.. and look.. its not so hard. did it with jack stands and limited tools in a tiny onecar garage.. and replaced my clutch..
skylet414
yea, well i bleed the lines checked for leaks(was none), n its still the same, so yea im just order a clutch kit, probaly try to take out the clutch soon, but anyone know if theres any write ups on it on this site.. im pretty sure there is but if anyone just might have it, itll be great help, thanks and thanks guys for the tips..
Spanky37
zerothread/168578
this one helped out alot.. its the one i used to do mine.. and i had never done anything with the trans before..
