Honestly, you might have the MAF too close to the throttle body. The MAD needs to be a good distance from the vacuum source to allow the flow to become uniform throughout the intake pipe. If you have it too close to the throttle body, the air can actually be pulled around the hot wire causing incorrect MAF readings.tmorgan4 wrote:
The stock tube was too long and pushed the filter out over the fender so I've got the MAF duct taped to the TB. It's on there pretty securely and I don't *think* it has any leaks, but it's a possibility. It could also be because I don't have the hose that goes to the IACV hooked into the intake and it's taking in free air that isn't metered which could screw some things up. I guess I should get a new shorter intake tube and hook that line up before spending a bunch of money on a new MAF.
The 2k is idle is an actual 2k not per the tach. The tach read more like 3k, but I bought a timing light with an RPM gauge on it and just left it hooked up to the #1 plug.
I'm not denying the possibility that you have a bad MAF either.
