evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Sep 16, 2011 1:51 pm
megatune had an internal write up on how to set and tune your fuel and ignition tables, I'm sure there are others, I personally just started with someone elses maps and tweaked form there with the aid of a wideband, to really tune the spark tables you need a chassis dyno
also when you set everything up it comes up with an estimated ve to begin with and you can scale the tables from there with 1 click that'll get it running enough to tune, or simply copy someone elses ve tables and tune from there
as for the settings thats gonna vary depending on your setup and your firmware version, I'm running HEI modules so mine is different right there, and each firmware version has it's minor differences for how the info is added and how many options you have, just take your time and realy wrap your head around it, I think I have to reread for a weak before I can fully get my head where it beeds to be for any serious megasquirt projects
the injectors well thats pretty self explanitory, just a matter of if you are running high impeadance ro lwo impeadance and wether or not you are runnign external dripping resistors, otherwise it's just a function of calculating your "req fuel"
