tErbo b00st wrote:...Another question. I have openings on my intake. 1 on the intercooler piping (blitz)near the throttle body, 1 on the APEXI intake kit, and 1 on the stock intake tubing to the filter. I have the intercooler one and the APEXI one blocked off and the other one going to the valve cover breather hose. Is that right?
And there is a lil vaccum nipple on the back of the intake manifold. Where does that go? again I have it blocked off.
The ic pipe opening by the throttle body should be plugged into your intake manifold iavc(a tube coming out from inside the intake manifold by tps). This helps the car start up and warm up with a smooth idle.
I don't get it when you said you have an opening on your Apexi intake kit. There should be two larger openings on the stock air intake, one for the pcv where stock oil catch can connects to that t bolt on the valve cover and the other opening is for rerouting the stock bypass valve back into the intake. Other small nipples on the stock air intake should be blocked off.
Where exactly is the small vacuum nipple on the back of the intake manifold? I don't recall seeing any vacuum nipples on the intake manifold unless you're talking about your fuel line nipples. One is on the fpr and the other is in between I believe runner 3 and 2 on the intake manifold. Both are for fuel lines.
