it seems my passenger side hood hinge is loose
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
aez2g
Car: 1993 300zxtt, 2004 g35
has anyone ever experienced this?
G_whizz
Car: 2010 G37 Coupe Sport
aez2g wrote:has anyone ever experienced this?
Welcome to NICO!!
Not to my knowledge!!??
How do you know it's loose?
Is the door not shutting flush??
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Hey there,
What is the hide hinge?
aez2g
The back corner of the hood catches the corner of the fender when opening the hood
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
That's what I highly suspected
Have you have some body work recently or maybe hit a large pothole?
It sound like you have a body alignment issue. The best way to check your body lines is to run your finger in the openings in the body panel (around door,hood,trunk edges).
I would say to run your finger around the sides of the hood. You should expect a gap of ~1/8" around the whole edge of the hood and fenders. I suspect you will notice a larger gap on the left side, if not then your fender is elevated. At that point I would check the gap in the passenger side door to the P/s fender.
If any of these things are found to be excessive you may want to contact a body shop for a thorough estimate and evaluation.
aez2g
I did take the car to the dealership just before my warranty ran out. they said this was not a warranty problem, did a little minor work at no charge, two months later the problem resurfaces. thats why I suspect that maybe the hood hinge may actually be loose --- I dont know how the hinge is secured to the body, I thought maybe if it is secured with faxteners they were loose.
Return to “G35 and G37 Interior, Exterior and Audio”
