It's Time to update the S14 suspension and I have questions.
MAXIMUS Nismo
Car: 95 240sx SE
Hello,
The car is a 95 S14 with 132,000 miles on it. It hasn't been driven for almost a 1 year but I've recently registered and insured it again. It will be used as a spirited daily driver.
Back in 2004, KYB AGX dampers + Eibach Prokit Springs were installed.
The Rear dampers are blown but I think the fronts are ok.
Looking back, the AGXs were nice because of the adjust-ability but I never used the car competitively, and the crazy roads in DC meant stiffening up the damping hurt my back and getting on the ground to change the settings started to get real old.
There is not a ton of money to be spent, only about $550 so with that in mind,
What would you suggest I pair with the Eibach Prokit.
What would you suggest I get instead of a Prokit + KYB GR2 combo?
Also, why do you make this suggestion?
Thank you for your time.
simmode1
Car: Red '95 S14
$550 budget & not interested in going low? Koni Yellows + Ground Control sleeves. There's an install & review article around here somewhere...
But I would rather hunt for some used Stance LX coilovers.
