It's the little things...
mandyg723
Car: 1990 infiniti q45
I'm sure someone else has (or has had) this specific issue... I'll elaborate.
Every now and again, when I go to remove the key from the ignition of my Q, she won't give it to me. Pisses me off. Ya know the little button you have to push in to release the key? It will just not want to depress. When this happens, I have to take off the little plastic piece surrounding the ignition (it just pops in and out) and push this little red lever back that lies next to the button- then the key comes out just fine.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You probably need a new ignition key and/or key switch.
CrimsonQ
Car: Purple People Eater
i wanna see you wiggle it, just a lil bit....
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
mandyg723 wrote:I'm sure someone else has (or has had) this specific issue... I'll elaborate.
I don't have the same problem as you, but my key sticks and I have to negotiate to get it out. I have to turn it back and forth and a few times before it comes out. The black button works fine me. In my case it's probably the cylinder.
Black stallion
Car: 1994 Infiniti Q45
2006 Infiniti QX56
I might would try a bit of graphite lubricant and make sure you don't have a pile of keys on your key ring. Heavy keyrings are notorious for ruining ignitions!
captainluigi
Car: 1996 q45t
had the same issue. dry graphite lube may fix your problem. use it in all locks.
mandyg723
I've been meaning to get some graphite- occasionally the trunk and the driver's side door will be sticky too.
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
2nd emotion
carfrk666
Car: 1993 Infiniti Q45
1995 Nissan 240SX
ive had this lovely problem, i donno, i just sprayed some liquid grafite in the key hole, and after time it had gotten alot better, sometimes it still does that because the shifter push knob didnt pop all the way back up when its put into park. i just sprayed some air into it and then some grafite lubrication.
