DoinkMobb »
https://forums.nicoclub.com/doinkmobb-u83966.html
Tue Apr 08, 2008 9:49 am
I did a half *** under the plenum job recently and got the car up and running again. I changed all the sparkplugs, as many hoses as I could reach or felt like doing, driver's side valve cover gasket, cleaned the TB, AAC, EGR...I think that's it. I didn't do the knock sensors or the driver's side valve cover gasket.*
I cranked the car over and it slowly roared to life. Awesome, at least it started. The idle seems unusually high, about 1500 rpm or so in park. Do my throttle cables need to be properly adjusted or what? It's not a huge problem, but it's kinda annoying to take your foot off the gas and the car lurches forward.
And apparently I did a pretty bad job on the valve cover gasket. It seems that both little half moons on the back of the valver cover (towards the firewall) became dislodged in the struggle of repositioning the cover. I hoped it was just old oil burning off but there's fresh stuff dripping on the exhaust. It's pretty bad, much worse than the old gasket that was on there.
So my half *** solution was to goop a ton of gray RTV all along the back of the valve cover. Will it work? I really doubt it. Am I going to remove the valve cover, reposition the gasket and put it back together? Not a chance.
My car doesn't feel any smoother or more responsive, I may or may not have fixed my coolant leak, my oil leak is much worse than it was, my idle is too high, I spent a LOT of money and my garage is a disaster area.
Oh well, live and learn. At least I tried.
*Listen, I know I could've done the knock sensors and passenger VC gasket and then the car would've been good for another 100K miles, but there's no way I'm keeping this car that long. It's a cool car and all, but it's not god's chariot. It's just a used car to get me around for a while.
