For those of you who don't know, my dp was thrown together at the last minute for like 30 bucks at the local muffler shop. They used 2 1/4" pipe and some pretty ugly crush bending. I have had problems with the pipe developing leaks and even breaking off since there was no flex installed. The pipe had just been welded to the end of my turbo outlet bend that houses the egt and o2 sensor and welded to the stock cat(gutted). I knew that this was one big weakness of my setup and it would have to be the first to go.
After even closer inspection (ie cutting the ****ing pipe off), I found this:
They had actually shoved the pipe inside the elbow, at an angle even! Can you believe this ****? There's about a 3/8" lip there on the outside of the curve right at the turbo. What crap. I effectively had a 2" I/D downpipe! Look at the rest of this thing!
This is it next no my new 3" flex pipe
