eastcoastchaos »
https://forums.nicoclub.com/eastcoastchaos-u4408.html
Mon Aug 08, 2005 3:51 pm
i was driving around about a week ago when all of a sudden my car started running really bad, unstable idle and when i would take off it would bog like crazy. it's been to the point where the only way i can move is to rev it a little and keep popping out the clutch. sometimes it will run perfect but most times it bogs every time i came from a stand still and a little every time i shift. i'm now 100% sure that theres no water in my gas tank and i don't know what else it could be. my distributor is the only thing i've been having a problem with lately, i have a 95+ motor in a 92 fastback, it has a 92 distributor on it and it's impossible to set the timing on it. 1 tooth in either direction make's it 5-10 degrees off. do i need a 95 distibutor with a 92 cap. or do i use a 95 cap and not use my ground wire?does this even seem reasonable or do i have bigger problems?thanks for any help in advance
