it's not that tech
eastcoastchaos
Car: 95 240sx
something is screwed with my brakes. when i hit a hard turn my brake light comes on (this doesn't really bother me). and when i come to a fast stop i hear a strange rumbley type noise from the brakes. i may just be low on brake fluid but if i'm wrong please feel free to correct me.thanks
Anand
Car: 95 Nissan 240SX
why don't you just ckeck and see if it is your brake fluid?? that would eliminate people trying to guess at it... also check and see if it is your brake pads.. maybe they are low.. you might need to replace them...
b240
Im pretty sure thats your pads grinding on your rotors. You will most likely end up having to replace the rotors and pads. Take off your tires and check them out , its not hard.
bj180sx
Car: cars
yes the rotors and if you have abs you might check that too
f8sjester
bj180sx wrote:yes the rotors and if you have abs you might check that too
LoL i swear i first read that as basically "check your stomach muscles" . . . dayam. . i must be tired. . .
