Some pics:
Modified by Woods Crasher at 10:30 AM 4/25/2007
Modified by Woods Crasher at 4:22 PM 4/25/2007
yea the open bov causes some problems but it's ok. going to recirc it eventually. The clutch is worrying me tho. when taking off in first there's a grinding sound, but shifting normally after that theres no grind. i'm hoping it's just cuz this clutch is crazy or something...i dunnoBwana wrote:Looks good! The atmospheric bov may give you some trouble, but you should be able to recirc that one if you need to.
It's an ARC front mount that uses the stock piping routejt15833 wrote:i run open bov too w/ no issues but im going to recirc as soon as possible. whats up with intercooler and piping? had those available? seems like a bit of extra tubing
It's certanly not a "bootleg" gauge. It's a blitz manual boost gauge. It reads 50 ish at idle and .5 boost at wot....or maybe it is a crappy gauge haha, i don't knowboost_boy wrote:I agree that 40-50ish hg of vacuum is totally abnormal for even a tightly built CA. I'll safely assume that you have either a bootleg boost/vacuum gauge or you just may be referring to the oil pressure. Crappy gauges will give you stupid readings.
Dee
this sound exactly like the same issue I had when I had a bad Coil.Woods Crasher wrote:
Not so big problem
The car drives funny when you're at part throttle. Like when driving through the neighborhood accelerating slowly to 25 - 30 mph. It's seems that when the boost gauge is at 0 the car hesitate and acts weird, but when you open up the throttle and get into boost and 3000+ rpm it's smooth. any thoughts? Grounds maybe? I checked all the vacuum lines and the only thing abnormal is the "L" shaped fitting for the ventilation hose on the exhaust side valve cover can easily be taken out of the valve cover. Like it just pops out... I was like..."that can't be right" So I gooped it with some black rtv and stuck it in.
Modified by Woods Crasher at 5:07 PM 4/25/2007
check your plugs and see if they are all working more than likely one will look brand new. I had to replace the 4th coil and the car now runs amazingly.
