desertq45 wrote:Hitman I'm assuming you don't pull a "hot" car into the garage then...
Actually, I installed a cooler that's rated for a 1500 square-foot house, and my garage is 30x22.
Installed upducts, and an insulated door, so when I pull in I click on the cooler - Within 5 minutes it's 80 degrees in the garage. The heat goes up through the upducts into the attic and out the turbine vents - When I turn on the cooler, and the wind isn't blowing, you can actually see the turbines on the house start spinning.
I'm planning to rig a pair of garage door sensors with a timer so the unit comes on for an hour after I pull in.
It's ghetto, but at least i can work in there in comfort.
