honestly, that is pretty damn cheap, materials will easily be up near $300 for a custom box, and there are a lot of materials that go into the trash OFTEN lolz. Plus you can not do a FG box in one day, it always takes on average 4-7 days, more than that for more intricately designed boxes and covers.weems84 wrote:looks great. I don't have the time or knowledge to make my own box. One guy i asked wanted 400 bucks and my car for 3 or 4 days!
Do you know what a capacitor is and what it does? In the car audio competition world, caps are useless. Caps in any setup are bandages to other problems. If your lights are dimming, this means that your charging and battery system are unable to keep up with the current draw that your system is demanding, and taking away from NEEDED electronics. To fix this you upgrade the big three. You upgrade all your power and ground wires throughout the car, you upgrade your alternator to a higher amp system, and upgrade your battery to a deep cycle. It is a shame that people always assume things instead of educating themselves. This has been proven, and there are plenty of people who know their ish on car audio who will tell you not to waste your money on caps, because they do nothing but bandage BIGGER problems. Ask anyone who perform in DB Drag and they will tell you. Ask them how many alternators they are running and how many amps each, and how many deep cycle batteries, and how many watts their system is pushing. THEN ask em how many caps they have and watch them laugh at you.Rockhound wrote:Hey man, looks great, darn near stock appearance. Despite all the nay-saying, I'm sure you'll really appreciate this project.
Just out of curiosity, I went out and did some research on car audio and capacitors in general. It's a heated debate on the subject, to say the least.
The problem is that most folks go off hearsay...they don't have much circuitry knowledge themselves, they just hear someone say "caps suck" and then they repeat it like a parrot. That's how much audio "knowledge" is passed around - there are so many myths out there, it's simply amazing. I'd say if they've worked for you in the past, then there's no reason not to continue using a cap.
I however won't pretend to be an expert, and I'll just say that it looks like you did a great job.
I've scoured over this thread, but I still can't find where Joe (jfanaselle) said that he's entering his Versa into stereo competition. Hmmm...guess I missed it.Clipsed wrote:In the car audio competition world, caps are useless.
Rockhound wrote:Clipsed, I'm not going to get into an ego-fueled p!$$ing contest with you.
You've really answered the question for yourself in that last post.
You're exactly right in saying that the capacitor acts as a "band-aid" - it really just masks weaknesses in other components. But, if it keeps Joe's lights from dimming when the sub "hits" - then I'd say the "band-aid" is working.
Believe it or not, not everyone is out to make their modifications stand up to "competition" levels. This forum is not about competition, despite your never-ending attempts to make it so.
I agree wholeheartedly. Unfortunately, if you choose to post something that doesn't pass muster with a certain self-proclaimed "expert", you're subject to puerile ridicule. One option would be to ignore it - the other would be to confront it. Personally I'm so fed up with it that I cannot sit back and watch it happen to every similar thread. One person shouldn't be able to ruin it for everyone else.marleyfan wrote:I think it looks good from a workmanship perspective. The bottom line is does the sound live up to your wants and expectation. Does the system function as it should and sound good. The rest of the discussion is crap.
Look at it this way, yes it adds "small resevoirs of power" for when the bass drops, but consider this, rap music, for example, has constant bass, so while your cap is trying to constantly recover those "small resevoirs if power", your losing even more voltage.jfanaselle wrote:Capacitors "stiffen" any electrical circuit by adding small resevoirs of power for items to draw from. Yes, it is true that it adds a load to the alternator by increasing the resistance....................... The capacitor will charge and discharge 100 times faster than a battery, which allows it to get power from the alternator when there is low demand on the system (between music notes) and supply power into the system when there is high demand (during a solid hit of the subwoofer). The fact is that capacitors work exactly this way, and if they didn't, then they wouldn't be installed in almost every single electronic component that you own to stabilize the current flow.
Funny how those who often talk about educating are the ones who need educating the most !Clipsed wrote:
Good luck convincing them of that, though.Jojo Versa wrote:Funny how those who often talk about educating are the ones who need educating the most !
Man; get over yourself. Not everyone needs to spend big bucks on components. I like sound, but can not hear the difference in a $100 sub vs a $1000 at the volume levels I want. I don't need the neighborhood to hear my music.Clipsed wrote:looks decent, nice job. Why waste money on that cap though, and waste that box on Sony Xplod, that is LITERALLY what is gonna happen to that sub unfortunately, they are amazingly crappy. Did you calculate the internal volume before adding resin? That was a lot of space you used, but good work.
It sounds great. There is one more small air leak that I am trying to track down. It's coming from an area behind where the amp rack is, so I'm having a hard time trying to seal it up. I think I might just try to get inside the box again with some expanding foam and see if I can get it that way. Once that's sealed up, it'll sound even better, and I need to add some poly fill to the inside because it's a little too small.XterraVersa wrote:jfanaselle looks good. How does it sound?
