mikalkouki »
https://forums.nicoclub.com/mikalkouki-u36365.html
Mon Mar 12, 2007 2:03 pm
My S14 w/ RB20DET swap is finally complete and tuned (for the most part)! I've still got quite a few questions, so everyone please give me your opinions.
1. Tuning- I've got a z32 maf, 3" exhaust, and everything else is stock. I've got my safc tuned to where I get close to 14-14.5 afr's under cruising speeds and 11-12 afr's under wot. Is that pretty close to where I wanna be? I've got my boost controller settings on Lo @ 6psi, Hi @ 10.5psi, Lo Gain 15%, Hi Gain 40%, Start boost @ 4 (wastegate starts to open @ 6.25psi), Warn (cut off) @ 12.2psi, Limit (what boost is reduced to after warn is engaged) @ 97% (10.19psi). For some reason with these settings I still get overboost in 4th gear above 5k, which is only just over 12 pounds and then reduced to 10.19psi, but it's still anoying to see the display turn red and reduce boost. Any suggestions? Boost controller is the PIT controller u can find on ebay for under 200 bucks as I did
2. Timing- I've set the timing to 20*BTDC and 30*BTDC. I can't really notice much of a difference and have read that some timing strobes will read 10* off. How can I know if this is my case and ensure my timing is set to 20*BTDC? I have an auto ECU in a 5spd. 20* correct?
3. Upgrades- I'm ready to start my quest for more ponies! What can I do to get the most out of the stock injectors for now and push the envelope safely? I have a walbro 255 and fpr. I also have access to some VG30DETT goodies for free from a buddy of mine. 370cc injectors, radiator and ignitor chip. Are any of these possible or worth swapping in on the 'ol rb20? I also have a huge *** .60 a/r (cold) 1.15 a/r (hot) turbo w/ t4 flange and top mount manifold with t3 flange. Is it worth the trouble to bolt this beast on, or would I be better off to get a smaller bolt on turbo for the stock manifold? One last stupid question.... I've got an atmos. bov and my stock bypass is still on the intake, but the vac. line is removed. Could this possible hinder the performance somehow? If so what needs to be done?
Sorry if any of this has been answered before and I really appreciate anyones input!!!
