daniel240 »
https://forums.nicoclub.com/daniel240-u4418.html
Mon Dec 29, 2003 8:25 pm
ok, well i took it for the first drive yesterday. overall it ran pretty good but i didnt push it. i did have a few problems. 1st, its overboosting. i got a crappy deltagate and i know thats my problem, but it says its a 5 psi spring, however it went up past 10psi and then i quickly let off the gas. holy **** that scared me, but i didnt hear any knocking. i thing the btm helped. i havent even gave it full throttle yet but its still fast as hell. i want to get it fixed so i can go wot. i think the wastegate is leaking. when i blow air into the hose going to the wastegate, i can hear some leaking out. should it do this? btw im probably buying a new tial anyways. my second problem was when i let off the gas quickly after accelerating it dies. almost evertime i come to a stop it wants to die if i let off quickly on the gas. what could this be? its not the bov, i ran it back to the intake. could it have anything to do w/ the wastegate? finally i had 2 more small problems, 1 im leaking a little oil around my sending unit "T". i keep tightening it but it keeps leaking. should i use some tape on the threads? also my downpipe is hitting on my steering column. i thought it would, that was such a tight fit when i made my downpipe. btw WD i will get you those installations for the btm, it was a ***** to install and is a lot harder than i had imagined. my dad is an electrition and it took me and him 4 hours to figure out. thanks for the complements, and please help me w/ my few problems. thanks.
ps: im using 370cc injectors w/ hacked mafs (2.6 id pipe) w/ a T3/To4e turbo.
