can you throw more info into this?im working on my own mounts, actually i wanted to use the rb25det mounts and crossmember since i have them bothI was thinking a spacer, i have access to a milling machine and already have some 7075/6061 stock waiting for me to figure out what im going to doI had it stuck in my mind to just put a spacer inbetween the crossmember and frame to lower the hole thing down.
Anyone know the exact clearance you need?
Or can anyone give me ideas?
jacksonbrown wrote:stock crossmember and hood closes without bracing cut. Mounts home made, Set pan 5/8" off steering rack and as far back as possible. I was watching down pipe to steering shaft and hood clearance to get the best of both.
Modified by jacksonbrown at 4:18 PM 10/5/2008
