I've had this bike for about 2 years now, bought it from my neighbor for $125. 1974 Yamaha MX175
I had ridden it before the previous summer and it ran great, but when he sold it to me the bike didn't have any spark. So began the process of figuring out wtf was the problem.
First I replaced the ignition coil, nothing happen. Put the old coil back on, and it fired up So I was pretty pumped about that, I guess? Then a few days later it wouldn't start, lost the spark again.
This time I pulled the magneto cover off and inspected the pulsar which was a bit corroded so I tried to clean it up and still nothing. Bike went into the barn not to come out for a whiiile.
Fast forward two years (last week) and I decided to screw with it again. This time I took a dremel to the contacts on the pulsar, carefully taking off the corrosion til it was clean metal. Put it back together, and we had ignition!!!
Next day, no spark. f*ck.
Tinkered with the pulsar again, changed the spark plug, ignition!!!!!
Next day, no spark.
At this point I was getting pretty pissed off that I couldn't figure out the problem, and I knew it had to be something on the pulsar, so earlier today I dug out the rtv crap covering the two wire connections on the pulsar.... low and behold there were only TWO STRANDS of one wire still connected. So whenever I pretty much touched the wires, it connected/disconnected/connected whatever.
So I busted out the soldering iron, redid both connections, and whah-la! I got spark
Hopefully I got the problem completely solved now, knock on wood.
test run through the backyard:
http://www.youtube.com/watch?v=b_O4W5t88ms
